updatedAt: 2026-09-08T21:31:59.000Z
agentTools:
  projectIndex: https://docs.observeinc.com/llms.txt
# Select light and dark mode settings
Learn how to set the light and dark mode settings for your Observe by Snowflake instance.
Hover on your user name in the left navigation rail, then select one of the following light and dark mode settings for the Observe by Snowflake user interface:
| Setting | Description        |
| Light   | Use light mode for the Observe by Snowflake user interface.                                                              |
| Auto    | Use your system settings to determine if the Observe by Snowflake user interface is rendered in light mode or dark mode. |
| Dark    | Use dark mode for the Observe by Snowflake user interface.                                                               |
