Collect StatsD metrics using UDS (legacy)
StatsD is a network daemon (originally written by Etsy) that listens for metrics (such as counters, timers, and gauges) sent over User Datagram Protocol (UDP) or Unix Domain Socket (UDS). Its primary job is to aggregate these metrics periodically and then pass them along to a backend service for storage and visualization. Below steps outline how to configure the Observe Agent to listen to a unix domain socket.
NoteTo view all available Agent Chart versions, run:
helm search repo observe --versions | grep observe/agent. If you're currently using Agent Chart versions 0.38 through 0.42, upgrade to version 0.43 or later.
- After the Observe Agent is up and running, create a
statsduds-values.yamlfile.agent: config: forwarder: receivers: statsd/uds: endpoint: ///var/run/obssocket/statsd.socket aggregation_interval: 60s transport: "unixgram" is_monotonic_counter: true enable_metric_type: true processors: attributes/debug_source_statsd_metrics: actions: - action: insert key: debug_source value: statsduds service: pipelines: metrics/custom-statsd: receivers: [statsd/uds] processors: [memory_limiter, k8sattributes, deltatocumulative/observe, batch, resourcedetection/cloud, resource/observe_common, attributes/debug_source_statsd_metrics] exporters: [prometheusremotewrite/observe] forwarder: extraVolumes: - name: "observe-agent-deployment-config" configMap: name: "observe-agent" items: - key: "relay" path: "observe-agent.yaml" defaultMode: 420 - name: obssocket hostPath: path: /tmp extraVolumeMounts: - name: observe-agent-deployment-config mountPath: /observe-agent-conf - name: obssocket mountPath: /var/run/obssocket lifecycleHooks: postStart: exec: command: ["/bin/sh", "-c", "sleep 20 && chmod o+rwx /var/run/obssocket/statsd.socket"] - Run the following command to redeploy the Observe Agent in the
observenamespace with the prometheusScrape configuration.helm upgrade --reuse-values observe-agent observe/agent -n observe --values statsduds-values.yaml - Run the following commands to restart the pods with the updated configuration.
kubectl rollout restart deployment -n observe kubectl rollout restart daemonset -n observe - Run the following command to make sure the Observe Agent has been redeployed successfully.
kubectl get pods -o wide -n observe - Once the Observe Agent is up and running on a Kubernetes cluster, configure your application running on the same Kubernetes cluster to send statsd metrics to the /var/run/obssocket/statsd.sock file.
- Explore your StatsD metrics using the Metrics Explorer.
Updated 2 months ago
