Collect StatsD metrics using UDS
StatsD is a network daemon (originally written by Etsy) that listens for metrics (such as counters, timers, and gauges) sent over User Datagram Protocol (UDP) or Unix Domain Socket (UDS). Its primary job is to aggregate these metrics periodically and then pass them along to a backend service for storage and visualization. Below steps outline how to configure the Observe agent to listen to a unix domain socket.
The following instructions are based on Agent Chart version 0.57 or later. If you're currently using Agent Chart versions older than 0.57, follow the legacy guide: Collect StatsD metrics using UDS (legacy). To view all available Agent Chart versions, run: helm search repo observe --versions | grep observe/agent.
  1. After the Observe Agent is up and running, create a statsduds-values.yaml file.
    agent:
      config:
        forwarder:
          receivers:
            statsd/uds:
              endpoint: ///var/run/obssocket/statsd.socket
              aggregation_interval: 60s
              transport: "unixgram"
          processors:
            attributes/debug_source_statsd_metrics:
              actions:
              - action: insert
                key: debug_source
                value: statsduds
          service:
            pipelines:
              metrics/custom-statsd:
                receivers: [statsd/uds]
                processors: [memory_limiter, k8sattributes, batch, resourcedetection/cloud, resource/observe_common, attributes/debug_source_statsd_metrics]
                exporters: [otlphttp/observe/otel_metrics]
    forwarder:
      extraVolumes:
        - name: "observe-agent-deployment-config"
          configMap:
            items:
              - key: "relay"
                path: "observe-agent.yaml"
            defaultMode: 420
        - name: obssocket
          hostPath:
            path: /tmp
      extraVolumeMounts:
        - name: observe-agent-deployment-config
          mountPath: /observe-agent-conf
        - name: obssocket
          mountPath: /var/run/obssocket
      lifecycleHooks:
        postStart:
          exec:
            command: ["/bin/sh", "-c", "sleep 20 && chmod o+rwx /var/run/obssocket/statsd.socket"]
  2. Run the following command to redeploy the Observe Agent in the observe namespace with the prometheusScrape configuration:
    helm upgrade --reuse-values observe-agent observe/agent -n observe --values statsduds-values.yaml
  3. Run the following commands to restart the pods with the updated configuration:
    kubectl rollout restart deployment -n observe
    kubectl rollout restart daemonset -n observe
  4. Run the following command to make sure the Observe Agent has been redeployed successfully.
    kubectl get pods -o wide -n observe
  5. Once the Observe Agent is up and running on a Kubernetes cluster, configure your application running on the same Kubernetes cluster to send statsd metrics to the /var/run/obssocket/statsd.sock file.
  6. Explore your statsd metrics using the Metrics Explorer.
