Monitor rules and severities
A monitor often includes multiple severities and desired outcomes. Observe monitors can use the full power of Observe to conditionally filter data.
The actions that are taken from a monitor's detections are filtered by severity. This allows powerful multi-level routing to be configured.
Use monitor rules to set severities
A rule determines the severity of a match. Common ways to configure rules are:
- Bands of severity based on the measured data
- Override severity for specific customers or objects
There are four severities: Informational, Warning, Error, and Critical.
A rule must set a severity. Multiple rules may use the same severity.
Trigger actions when a rule matches
When a rule matches, an alert is created which can be reviewed in Alert Explorer.
If there are no muting rules in effect, then the alert may trigger action. See Mute a monitor.
Each action is filtered by severity. Common ways to configure actions are:
- Send all alerts of any severity to S3 for compliance storage
- Send Informational or Warning alerts to Slack only
- Send Error or Critical alerts to Slack and PagerDuty
Multiple actions can match a single severity.
Updated 18 days ago
