How do I extract the numeric parts of a message?
Note that if the message looks like a date, you can use parse_timestamp on it only if the message is consistently structured. There is no parse_duration function.
To extract the numeric parts of a message, you can use the get_regex_all function. For example, assuming you have a column called message in your Dataset containing the string you want to parse, you can use the following:
make_col numeric_parts:get_regex_all(message, /d+/)
This will create a new column called numeric_parts that contains an array of all the numeric parts found in the message column.
If you want to extract the numeric parts of a specific string, you can do that as well:
make_col numeric_parts:get_regex_all("348 days, 10:49:44", /d+/)
Updated 10 months ago
